Fanvil X6U phones display blue screen with 'Same file' message
Leo_B
A strange situation: on Friday and Saturday, users from two of our phone systems started reporting that their phones were glitching and displaying a blue screen with the message "Same File!". As is often the case, we only learned about the issue after the phones had already returned to normal operation, so unfortunately no photos are available.
The only two things these systems have in common are:
-- Both use Fanvil X6U phones.
-- Both were upgraded to 3CX v20 Update 10 on November 11.
Has anyone encountered similar behavior?
AI suggests the following explanation:
According to Fanvil's provisioning documentation, when the phone downloads a configuration file from its provisioning server, it compares the downloaded file with the configuration already stored on the phone. If the contents are identical, the phone aborts the update and reports that the file is the same.
That sounds reasonable, but it raises another question: why haven't we seen this before? We've been using X6U phones since 2023, and their auto-provisioning interval has been set to the default 720 minutes the entire time. If this is simply normal provisioning behavior, I would have expected it to appear long before now rather than immediately following the Update 10 upgrade.
Version 20.0 Update 10
AI Edition 16 SC
self-hosted (Vultr VM)
Reactions: MattJ
Have you looked at the "Options" under Phones page? I think U9 or 10 implemented additional features to scheduled firmware.
Good tip (thanks!). However, I'm not seeing any useful clues there.
Hi Leo,
1. Go to Admin Console > Phones
2. Select all your Fanvils
3. Click "Clear Firmware"
The phone will show it every time it does a firmware check, and finds that the firmware file is the same version as the one it has installed now. Firmware checks are done once a day, during reprovisioning.
We have asked Fanvil if possible to not bother the user with this message unnecessarily, by changing the behavior in a future release.
Reactions: KyriacosS_3CX
Hello John,
Thank you for the clarification! What seems odd is that, according to feedback from our clients, the firmware check is occurring much more frequently than once per day. Some users report seeing the message roughly once an hour, while others claim it appears even more often.
Additionally, we had never encountered this behavior before last week and the upgrade to Update 10. Prior to that, the "Same File" message was not appearing at all.
AI Edition 16 SC
We are seeing the same behaviour with X6U and v20 Update 10, and have not seen this before. We've been using 3CX and Fanvil for years...
Version 20.0 Update 10 (Build 1785 Release - AI 1.6.91)
8 PRO, on prem
Hi Leo and Matt,
This happened in older versions too, it's just more noticeable in U10 with Fanvil devices: before U10, a firmware URL stayed in provisioning (causing these messages) until you edited the phone (like changing a BLF) which cleared it out. With U10's new, more granular firmware management system, the link stays assigned until you choose to clear it yourself, and won't come back unless you push new firmware or re-add the phone. The initial auto assignment covers some cases coming from U9 and older, converting them to the new firmware library. After that, if you unassign the FW, it will stay that way and not bother you.
We are looking into some improvements for this that should eliminate the annoying message without sacrificing your granular control.
We're experiencing the same issue with Fanvil X210 phones running firmware version 2.4.19. We deleted the firmware assignment as described above, but the message keeps reappearing. Does anyone have any ideas on how we can stop this?
Hi Stephan,
Once you clear the FW assignment, the phone needs to reprovision once to forget the firmware URL.
If you do nothing, it should reprovision within 24 hours and stop showing the message on its own.
If you reprovision it once, it should stop immediately. This applies in U10 specifically.
Send them a reprovision command and let us know how it goes.
youwillbrun
