Fax Issues in V20
nerminat0rr
I currently have a new V20 Setup Hosted and I unable to send out faxes using my HT801. Phones are working great.
Fax Trunk is all green and HT801 is green
Now what I am unsure about is if the Default Route of ending call is wrong.
I also contacted Telnyx if they see anything going through and nothing on their end.
I updated my HT801 and upload the current configuration I have.
I also attached a screenshot (HP Test Fax). I tried different Fax Numbers and I keep getting this error and I also tried a different fax machine.
PLEASE HELP
Screenshots are below.
Fax Extension -
...and, have you had a look at the 3CX Activity Log after a call attempt?
@nerminat0rr Can you please set the fax extension number as prefix in the outbound rule and let me know if this works?
Your outbound rule is for numbers starting with +1. Is the fax machine actually dialing the + ?
@nerminat0rr Have you created the outbound rule with only the virtual extension number as prefix and on the top priority but still the same?
lastshadow
