Faxing
JasonD
We are new to 3CX and have a couple of questions related to the Fax Server feature.
1) Can we receive faxes on more than 1 did?
2) Can it route the faxes to different email addresses based on the DID the fax came in on?
3) Does 3CX, like many other PBX solutions, allow for end users to "send" faxes from their email (i.e. similar to what you can do with Ring Central)?
- If not, is there a 3rd party eFax service that works with 3CX for this functionality?
Thanks,
Jason
1. Yes
2. Yes, you can route faxes to the mail of any existing extension
3. No
4. Any fax solution that will speak SIP can be configured to work with 3CX, but none are tested/supported. But you don't necessarily need anything to work with 3CX. Often easier to just port your specific fax numbers to a fax provider.
martin1176
