Feature request: SIP Trunks sorting alphabetical / show under Phones if a PC is plugged in
m151-a1
Gold Partner
Het, I have some suggestions to put out here:
1. Is it possible for the SIP Trunk page (incl. DECT/Fax) to be sorted alphabetical? That would be very helpful; Can be quite messy in a MultiTenant setup
2. For sites where there might be a computer connected to the PC port of an IPphone, can there be a grey or green dot implemented on the Phone page showing that this port is being used? Is helpful when upgrading the firmware, so that the admin knows NOT to upgrade as long as the PC is connected during Office hours. Reading the firmware version and the type of the phone, this shouldn't be a problem to read if the PC port active or not.
No, the PBX does not know whether the port is occupied or not. The phone does not report anything to the PBX in this regard.
/dev/simon
