Solved Feature Request - User Phone Model - More Detail
Nick7300
I would like to offer a feature requst.
When logged into the 3cx admin interface, When I go to Admin >> Users >> Select User >> IP Phone
If I want to delete a specific phone I know that I can select it from the dropdown list, and then click delete.
However if the user has multiple phones of the same model, the Phone Model dropdown list just has multiple of the same item listed, so I have no clue as to which one to remove.
Proposed solution would be to have the dropdown have the Phone Model - <mac address>
Hello, this is not how feature requests are submitted.
Only partners in the higher tier can submit these, I would recommend you find one to see if they'll post on your behalf.
I'd make sure something like this doesnt exist in ideas already too.
That is a good shout though.
As a workaround perhaps you could duplicate an existing template giving a custom name and since avoid having the exact same name. Of course, worth it only if you have few phones to distinguish
@Nick7300 depending on which phone you will select, you can still see the MAC address on the Configuration section.
Check screenshot below.
Select the one you want and delete it.
Solution
That works great! Would be nice to have in the list so I wouldn't have to go through each one, but this definitely works. Thanks!
Reactions: NikosT_3CX
ARKC
