Final Warning - Upgrade to v18
User3Inc
Please upgrade to version 18 by November 30th, 2022. After this date, v16 is EOL and can no longer be activated; which means all communication via your 3CX system will be disrupted.
Upgrading to V18 ensures your 3CX system will continue to operate, without any issues. You will also enjoy additional benefits, which are included in your 3CX subscription:
  • Video Conferencing
  • Mobile Apps
  • Enhanced Security
  • Many new features!
What should I do?
  • Check out this information
  • Contact a 3CX Partner
I have received this email and just wanted to clarify this is referring to the 3CX system need to be V18. The clients do not need to be updated e.g. 3cx for windows, desktop app?
  • Mobile Apps
  • Enhanced Security
What should I do?
Yes the system needs to be up-to-date and well, apps should be as well once the system is.
Reactions: JorisR_3CX
Yes, this email concerns the server version , not the apps (You apps should also always be up to date). You should make sure that your PBX is up to date from it's management console. If it already is , no other action is needed.
megalmazan
