Solved Firewall Failed with Ports Correctly Forwarded
I reinstalled 3CX 15.5 on a Windows machine that previously had no firewall issues, but now the firewall fails. I have rechecked the ports are forwarded correctly and rebooted the router and Windows firewall, but still the same problem. Here is what I get:
testing 3CX SIP Server... failed (How to resolve?)
  • stopping service... done
  • detecting SIP ALG... not detected
  • testing port 5060... used by '3CXPhoneSystem':1932 (How to resolve?)
Well...port 5060 should be used by 3CX so I'm not certain why that is seen as an issue
Does the PBX work, on that machine? Or are there issues?
Was there a previous install of 3CX on that machine? Perhaps something of the previous install remaining?
Well, it resolved on its own. I ran the firewall several times and it kept failing with the same issue, but then it was suddenly resolved.
Glad to see the issue has been resolved. My guess is that something was using the port and that gave you an error.
Jake R
