First Deployment
kylejwx93
Rolling out my first 3CX deployment on Monday. I've tried to check all the details, but I'm sure I'm missing something. What are the most common mistakes with a new VoIP system?
Is something not working or..?
Have you done testing? Is it hosted, or local? There are a lot of variables, but if you have tested the installation, and more importantly , been able to place calls in and out for most (all?) scenarios, then the major concern may end up being the local network hardware. There are always going to be unforeseen problems, that are not discovered until the PBX is actually in operation. The hope is, that you are able to resolve them quickly.
hughesdouglas
