first ever instal 3cx debian without start onboot
Tiltjm
Platinum Partner
Hi, this is my very first installation of 3cx non-cloud.
I'm trying to instal on a minipc from pc engine.
When I use the iso on 3cx website, after the debian instal, 3cxpbx config should not automaticly start?, when I reboot, what is the command line to execute the startup of 3cxpbx?
thanks
Yes the install should start automatically.
Hey @Tiltjm,
Using the 3CX ISO for deploying the Debian 9 machine should automatically drop you into the 3CX Installation Wizard right after the OS's configuration is complete. Specifically, it will ask you if you wish to install 3CX via the CLI or Web Wizard.
The commands you mention were used to install 3CX manually on fresh Debian 9 deployment(not the 3CX ISO) which is no longer a 3CX Supported method. I recommend that you make sure you have downloaded the latest 3CX ISO and then do a fresh install following the step-by-step guide found here: https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
You may also want to consider having a quick read through our Hardware Requirements: https://www.3cx.com/docs/recommended-hardware-specifications-for-3cx/
kevlaboom
