- Joined
- Mar 13, 2023
- Messages
- 3
- Reaction score
- 0
I have the dial code for "Force 3CX Phone System to IN or OUT of office" set to *992
Dialing *9921 gives the correct response of IN office
Dialing *9922 gives the correct response of OUT of office
Dialing *992 returns the system back to the default office hours
If you have the office hours setup through the web client with open, closed, and break routes going to various digital receptionists, it does not work. Despite the dial codes apparently confirming they changed the IN/OUT status, the system continues to route the calls based on the office hours. From what I can tell, you can't use the IN/OUT dial codes with the web client office hours routing. The interface or documentation doesn't seem to identify that behavior as something by design and I would consider it a bug. Or is there a different dial code or method for forcing IN/OUT for the web client based office hour groups?
The IN/Out codes do work if you are using the global office hours through the management console and setup routing through the inbound rules, but it seems like the web client is the preferred method in the documentation: https://www.3cx.com/docs/manual/ivr-digital-receptionist/#h.gadcjzghtafl.
Thanks!
Thanks!
