Force 3CX Phone System to IN or OUT of office
Pascal_101
is it possible to force different ring groups in or out of office ?
the scenario is we have a callcenter that's open from 08:00 to 20:00 and an office that's open from 06:00 to 19:00.
users want to open the ring group with a dial code.
all groups have different trunks.
You can set opening hours on the trunks, option you are looking for - Set up Specific Office Hours for this trunk
true i got this set up, but sometimes the office goes home early and i dont want to change the opening and closing times
Additionally this guide will explain the "force" element for dial-codes:
https://www.3cx.com/docs/pbx-dial-codes/
This is a global feature however designed for when there is an emergency for the entire system.
i
i've seen this *8 but i think it means the entire system wil go in or out of office, so if someone in the office uses it, the callcenter is out of office also
Yes, this will put the entire system out of office - this is not what you want.
Techmansam
