Solved force display name change in real phone (snom) from management console
ubsysteme.de
If I change the first name and last name of the extension in the management console the name is not changed in the phones display. I have to restart the phone.
Is there a way to force this change without restarting?
3CX 15.5.10244.4
snom D715
Regards
3CX should update the phone once every 24 hrs, so you could wait until this happens or force the update.
Within 3CX Management console, select the extension under Phones and click on 'Reprovision' tab along the top
Thank You.
Is there no other/fast way like change the current profile to DND? This is updated immediately.
Regards
The phone needs to get the new name from the server. This can only be done by re-provisioning or rebooting the phone.
OK. Thanks again for the information.
Glad we could assist.
Jake R
