Forwarding rules
mikegyit
I am trying to configure an extension to forward to a mobile number if it busy or unregistered. I created the forwarding rule, the extension is unregistered and when I attempt to call it, the call just drops. I checked the activity log and it tells me that there is no outbound rule created for the mobile number I entered in the forwarding rule. Before the v16 update, I had this working how I have it set up now. I believe.... What am I missing?
[CM303006]: There's no outbound rule for external number 'xxxxxxxxxx'' defined (xxxxxxxxx is the mobile number I'm attempting to forward to. I have outbound rules configured properly for regular calls. I can call that mobile number normally from the same PBX and it rings just fine. But if I call the extension when it's busy or unregistered to test to see if the forwarding rule is working, the calls drops and the activity logs throws that outbound rule error.
When you test this are you testing from a phone on the PBX - or calling in from the outside?
Does the xxxxxxxxxx match exactly? ie: any hyphens or +1 in there?
in V16 outbound rules have been locked down, where some worked in V15
You need to create an outbound rule for mobile number or adjust your rules.
hughesdouglas
