Solved FQDN binding with wrong IP
ajay8100
I am having some issues with FQDN binding with wrong IP address.
I am creating a new instance in cloud (OVH/Amazon LightSail) but the build is failing every time.
After few minutes the FQDN is registering with my WAN IP instead of the WAN IP of the cloud instance that I am creating and the instance creation process continues to run for hours.
I tried multiple times and every time the FQDN registers with my WAN IP
Thanks...
If you didn't turn off your old instance that will happen. Also the DNS updates can take up to 6 hours (for standard keys) to update. So make sure your old instance is offline, and stop reinstalling or you will get the LE limit on cert generation.
@ajay8100 can you PM me with your license key to check it ?
@ajay8100 I have found the key and as I can see we already have a ticket open in the Cloud Team about this.
Your FQDN is bound with a Public ip address because we can see requests coming from this site to our Activation Server from a PBX. You mentioned that this is the ip address of your office, but I would recommend to check if you have forgotten a VM turned on with a PBX installed and having this key installed on.
footandankle.my3fcx.us
