Solved FQDN Issues with Amazon EC2
gbrown100
Hi everyone,
I normally use OVH or Lightsail (with one Azure as free for charities) for hosting. I had an OVH instance corrupt (not for the first time) and so to restore from backup I used the wizard and installed on EC2 instead as I needed to stick with V18. The issue I have is that although initially the FQDN was pointing at the correct IP address it's now resolving to a different Amazon IP address - one that I don't own and is not assigned to the instance.
Sorry - wish you could delete posts once created! This is solved. It was a previous attempt to restore from backup on lightsail that actually worked but took it's time, it was grabbing the FQDN back. Now deleted.
cur_cb
