Free Upgrade from 12.5 to 15.5
godskitchen
Intermediate Cert.
Hello all,
I received an email some time ago advising that there is a free upgrade for anyone in an older version of 3cx.
I have searched and can't find the info I need or a guide.
Is this free upgrade still available?
Do I need to move up from 12.5 through each different version until I reach 15.5 (I have read conflicting information as to which path will work/be eligible for the free upgrade)
Many thanks in advance and apologies if I have missed this information elsewhere
Thanks for the reply but the info in the link doesn't apply to my situation at all.
Reactions: godskitchen
Hello @godskitchen
Please note that your licence will only be able to activate to V15.5 sp6 so you need to upgrade to that following the upgrade path. You will need to upgrade to V14, perform a backup and upgrade to V15.5. If you have active maintenance you should be ok to activate. If your maintenance is not active then contact our customer support department https://www.3cx.com/contact-form/
Hello @godskitchen
Thanks for that information just what I was after.
There is no maintenance on this install, what should I do to reduce down time re activation?
You will need to contact our customer support before upgrading so that you are able to activate once you reach V15.5
laranicole.lucus
