I'm looking everywhere, but i can't find anything.
Is there a way to configure by provisioning the "Friendly Name" (for livechat/meet) of every extension/users on a 3CX instance ?
Ok Thank to you, but i'm aware of this.
So there is no way, that i can per default set the value of thie friendly name for all users ?
Each user must to it by themselves.
Example : specific header, on the csv import/export in the users ?
It would be nice if the friendly name had a default value of the extension number if this is going to remain a required field. If you import a large amount of users or a PBX admin prefers to use the webclient admin as opposed to the management console, it is time consuming for them to have to set this for each user they want to edit.
