"FTP server Fail Delete Clinet"
a.orxan
Hi everyone, i have problem FTP server. I'm connecting FTP server but Backup Schedule didn't working.
Fri Sep 10 16:56:00 2021 [pid 13766] CONNECT: Client "172.16.1.88"
Fri Sep 10 16:56:00 2021 [pid 13765] [3cxftpuser] OK LOGIN: Client "172.16.1.88"
Fri Sep 10 16:56:00 2021 [pid 13767] [3cxftpuser] FAIL DELETE: Client "172.16.1.88", "/3CXScheduledBackup.zip.tmp"
Does the user you are connecting to the FTP server have full rights to create / modify and delete files on the folder
775 means that all other users do not have write permissions. Either try 777 or make the user owner of the folder and it's contents or add him as a member of the owner group.
If you use FileZilla, connect to the FTP server - can you delete this file in question , rename files , create files.
I can try all permison but not working FTP, now try SFTP server Backup Schedule working
Nari
