GATEWAY - IP PROVISIONING LINK SHOWS OLDER IP
PCProjectcfu
We switched the router we use for our 3cx Debian on-premise installation on a new router. (192.168.X.Y) to (192.168.Z.B)
If I provision our grandstream to the new one it works perfectly and everything provisions. (USING 192.168.Z.B)
However the provisoning link shown on the SIP Trunks page for the Grandstream Gateway is the old link (192.168.X.Y) and everytime it refreshes on the grandstream management console webpage it shows the old one (192.168.X.Y.). I'm worried this might cause a few issues once it reprovisions or does any update.
I can't get the old IP to disappear. Any help?
Hi @PCProjectcfu
So did the local IP of the PBX change? If it did then you should see a warning on the dashboard alerting you of the change. If you press that and it switches over to the new IP.
If you never got the warning then you probably never restarted the services since the change. Restart everything and see if the issue is resolved.
Reactions: JohnS_3CX
awan05
