Generic SIP Trunk V20
Alex Aubert
Gold Partner
I got an Issues with incoming call only showing the number ; I did test with a supported provider and the name did pass ... but with generic I only see number ... the provider says he is passing the info but I dont see it on my side.
On the Trunk with Voxtelsys
12/19/2024 10:19:04 AM Rhesus Inc. (+18197582220) Aubert, Alex (100) Unanswered 00:00:08 00:00:00 0,00 Terminated by Rhesus Inc. (+18197582220)
With the Generic Trunk
19/12/2024 10:21:40 8197582220 ADMIN RHÉSUS (100) Unanswered 00:00:05 00:00:00 0,00 Terminated by 8197582220
Is there an option I could change to get the name as well.
You need the template to be adjusted for this provider, so you should ask them to do this and create a template for you to run 3CX with their service..... And make sure they will do the testing and support
Reactions: PaulC_3CX
Thanks, I did import the new template and its work now the issue was here in the generic template:
</codecs>
<field name="Source" custom="" parameter="ContactHost">$GWHostPort</field>
<field name="ParameterIn" custom="" parameter="ToUserPart">$CalledNum</field>
<field name="ParameterIn" custom="" parameter="FromUserPart">$CallerName</field>
changed for:
<field name="ParameterIn" custom="" parameter="FromDisplayName">$CallerName</field>
Reactions: Sajjad.Khurshid
Well, maybe you can say what the provider name is so other people using the provider can make same change. Ensure you use a provider that is going to support you with using it with 3CX.
Its Sogetel we are in Quebec, Canada
tohoken1
