Solved Generic Voip Provider missing
BABALUCHA
Hello Everyone
First of all thanks for stopping by and helping out.I just made a trial intance on 3cx hosted platform for a test drive and want to use Generic Voip Provider which is not listed in my country Canada or even USA etc.I want to add Generic Voip Provider for service .i was able to do this in the past on 3cx hosted instance.
3cx hosted needs to use a supported 3cx hosted sip provider, reasons you cannot see generic sip provider.
I believe if you restore / migrate a system with a generic sip provider, it does setup the generic sip trunk
https://www.3cx.com/ordering/pricing/hosted-info/
Thank you , I was able to work around ,i picked one of the provider from the list and edit few settings and i was bale to make the Trunks work.thanks again for your help and time.
awan05
