Global Phone Book Disable?
greatchoice
I am looking to disable the global directory in the W60B handsets.
I set different groups up. I do not want 1 group seeing the other groups extensions. I can't find another option to do this.
Drill down into the extension of each user in the group, Options, Options, Hide this extension from 3CX company phonebook and 3CX Apps. Does this help you out? I don't think there is a way to sperate groups from seeing each other because you can still search for them.
Reactions: JohnS_3CX
You can either hide the extension from everyone's phonebook or individuals like @rgruber said.
It is not possible to hide groups of contacts from other groups of contacts.
Reactions: greatchoice
Cloudstar
