Google Buckets as a Backup Storage
Mike94
Has anyone else setup call recording archive with Google buckets and if so, how did you estimate Class A and B operations ? I'm considering to start using Google's cloud storage,although I'm fairly confused how to estimate a total monthly cost.
Any suggestions would be much appreciated!
Cheers,
Mike
Reactions: James Windiate
Looking forward to seeing any replies to this as I’m interested also.
Reactions: Mike94
Are we really concerned about pennies here? Set it up, watch it, get your numbers.
Hi, the backup will also contain the call recordings, so I believe it can generate more network traffic on the buckets, hence trigger more A & B operations. I'm ideally looking for a clue how to estimate roughly the overall cost per month, as the Google's documentation doesn't explain it any clear. If we're talking about the pennies that's great, nothing to worry about. Although, I'm not sure if I don't generate much higher costs by uploading a big amount of call recordings every day.
hughesdouglas
