Google SSO
BellS
Probably me not understanding something but the release notes for v18 suggest SSO with Azure/Google is now supported; https://www.3cx.com/blog/releases/v18-final/
I can't find any documentation for how to configure it. Can't see any of the options outside of the 'Microsoft 365 Integration' in Settings.
The screenshots show it appearing in the web client but it isn't on my install.
What am I missing?
Do you not have the option under Settings >> Integrations?
What exact 3CX version(Dashboard >> Information >> License) are you running and what License Key(Std,Pro,Ent)?
That makes more sense. I'd assumed that we were running V18 as it was a recent download.
We're running V16 as there doesn't appear to be a V18 for Windows server. I'll probably just wipe and re-install as this is a new build.
Yes, 3CX V18 has yet to be released as a stable version. You can find the Windows Installer for 3CX V18 Update 1 Beta 2 here, but, if this is going to be a production PBX I would not recommend using a Beta version and preferably wait until the 3CX V18 for Windows is officially released.
gdstratton
