- Joined
- Aug 7, 2017
- Messages
- 45
- Reaction score
- 6
One of my sites has Gradwell SIP Trunking - worked perfectly for 8 days up to and including Friday 26th March Office closed
Office open Monday 29th March and although incoming working ok all outgoing calls are failing via Gradwell Primary route and dropping to other ISP route 2
EVENT LOG gives following entry
Call or Registration to 01142510676@(Ln.10000@Gradwell Communications) has failed. 109.224.232.216 replied: 403 Access denied to SIP Trunk Out; from IP:109.224.232.216:5060
SIP Server ID: 12294 30/03/2021 19:57:42
Although has worked for over a week I checked and Made sure that on the extensions that fail do not have an outbound caller ID set that does not belong to myr Gradwell account. Also have made sure all calls use the same outbound rule.
ACTIVITY LOG has following entry
30/03/2021 19:57:42 - [CM503003]: Call(C:3): Call to <sip:[email protected]:0> has failed; Cause: 403 Access denied to SIP Trunk Out/INVITE from 109.224.232.216:5060
Thank you. Any thoughts and guidance very welcome
Windows 10 PC based 3CX v16.0.8.9
