  • V20 Update 10 Final Learn more
Grandstream GSC3516
Colorado VoIP
Gold Partner
It looks like the GSC3516 is the new replacement for 3510 2 way paging speaker. There is no template on 3cx for these speakers, but I was curious if anyone has tried using the 3510 template?
Have a building with about 25 of these speakers they'd like to integrate onto 3cx.
Thanks!
We would like to see an official 3CX template for the Grandstream GSC3516 SIP speakers. We currently have one 3516 that we're testing in our environment with the 3510 template. It works for the most part, but things like whitelists aren't populating from the template; we have to enter those values manually on the back end of the speaker. Provisioning, however, does work well with the 3510 template, so I don't think you'd run into any major issues if you decide to roll it out. In the 3CX console, when you click on Users, the 3516 User column shows as green, but the IP Phone column for the 3516 with the 3510 template shows red (like it's down/not connected). Everything works, it's just annoying seeing that red. :)
BConveryCoreCare
