GrandStream GXP1760W Scan Error "Wifi not working"
CarlosHenriquez
After upgrading the Phone to the 3cx firmware 10.0.1.116 the phone has lost the wifi capability, the phone is not even accepting firmware downgrade with tftp server. The problem is that we use the phone just in Wireless, because there is no ethernet available in the position, right now the user doesnt have a way to communicate with no one.
This is the output of the log viewer:
Connection received from 10.0.0.159 on port 44642 [19/10 21:58:07.289]
Read request for file <language.txt>. Mode octet [19/10 21:58:07.298]
File <language.txt> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:07.298]
Connection received from 10.0.0.159 on port 58694 [19/10 21:58:48.754]
Read request for file <cfgMac-Address.xml>. Mode octet [19/10 21:58:48.754]
File <cfgMac-Address.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:48.754]
Connection received from 10.0.0.159 on port 45723 [19/10 21:58:48.765]
Read request for file <cfgMac-Address.xml>. Mode octet [19/10 21:58:48.765]
File <cfgMac-Address.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:48.765]
Connection received from 10.0.0.159 on port 52420 [19/10 21:58:48.765]
Read request for file <cfgMac-Address.xml>. Mode octet [19/10 21:58:48.773]
File <cfgMac-Address.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:48.773]
Connection received from 10.0.0.159 on port 59205 [19/10 21:58:48.795]
Read request for file <cfgMac-Address>. Mode octet [19/10 21:58:48.795]
File <cfgMac-Address> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:48.795]
Connection received from 10.0.0.159 on port 36134 [19/10 21:58:48.795]
File <cfgMac-Address> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:48.803]
Connection received from 10.0.0.159 on port 56428 [19/10 21:58:48.803]
Read request for file <cfgMac-Address>. Mode octet [19/10 21:58:48.803]
Connection received from 10.0.0.159 on port 47206 [19/10 21:58:48.827]
Read request for file <cfggxp1760w.xml>. Mode octet [19/10 21:58:48.827]
File <cfggxp1760w.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:48.827]
Connection received from 10.0.0.159 on port 44150 [19/10 21:58:48.901]
Read request for file <cfggxp1760w.xml>. Mode octet [19/10 21:58:48.901]
File <cfggxp1760w.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:48.901]
Connection received from 10.0.0.159 on port 57966 [19/10 21:58:48.936]
Read request for file <cfggxp1760w.xml>. Mode octet [19/10 21:58:48.941]
File <cfggxp1760w.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:48.941]
Connection received from 10.0.0.159 on port 47947 [19/10 21:58:49.147]
Read request for file <cfg.xml>. Mode octet [19/10 21:58:49.147]
File <cfg.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.147]
Connection received from 10.0.0.159 on port 33645 [19/10 21:58:49.151]
Read request for file <cfg.xml>. Mode octet [19/10 21:58:49.151]
File <cfg.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.151]
Connection received from 10.0.0.159 on port 45974 [19/10 21:58:49.159]
Read request for file <cfg.xml>. Mode octet [19/10 21:58:49.159]
File <cfg.xml> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.159]
Connection received from 10.0.0.159 on port 52148 [19/10 21:58:49.667]
Read request for file <gxp1700fw.bin>. Mode octet [19/10 21:58:49.667]
File <gxp1700fw.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.667]
Connection received from 10.0.0.159 on port 44708 [19/10 21:58:49.675]
Read request for file <gxp1700fw.bin>. Mode octet [19/10 21:58:49.675]
File <gxp1700fw.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.675]
Connection received from 10.0.0.159 on port 35693 [19/10 21:58:49.675]
Read request for file <gxp1700fw.bin>. Mode octet [19/10 21:58:49.683]
File <gxp1700fw.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.683]
Connection received from 10.0.0.159 on port 47514 [19/10 21:58:49.699]
Read request for file <ring1.bin>. Mode octet [19/10 21:58:49.699]
File <ring1.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.707]
Connection received from 10.0.0.159 on port 55281 [19/10 21:58:49.707]
Read request for file <ring1.bin>. Mode octet [19/10 21:58:49.707]
File <ring1.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.715]
Connection received from 10.0.0.159 on port 60013 [19/10 21:58:49.715]
Read request for file <ring1.bin>. Mode octet [19/10 21:58:49.715]
Connection received from 10.0.0.159 on port 51029 [19/10 21:58:49.748]
Read request for file <ring2.bin>. Mode octet [19/10 21:58:49.748]
File <ring2.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.748]
Connection received from 10.0.0.159 on port 58643 [19/10 21:58:49.756]
Read request for file <ring2.bin>. Mode octet [19/10 21:58:49.756]
File <ring2.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.756]
Connection received from 10.0.0.159 on port 38995 [19/10 21:58:49.764]
Read request for file <ring2.bin>. Mode octet [19/10 21:58:49.764]
File <ring2.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.764]
Connection received from 10.0.0.159 on port 43498 [19/10 21:58:49.780]
Read request for file <ring3.bin>. Mode octet [19/10 21:58:49.788]
File <ring3.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.788]
Connection received from 10.0.0.159 on port 35523 [19/10 21:58:49.796]
Read request for file <ring3.bin>. Mode octet [19/10 21:58:49.796]
File <ring3.bin> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 21:58:49.796]
Connection received from 10.0.0.159 on port 43349 [19/10 21:58:49.796]
Thanks for the help
Hi Carlos,
I think it's pretty clear that in this case you would be better off contacting Grandstream support and provide them with any logs they require.
We do not provide any support for WiFi connections on IP phones regardless of the issue.
SupportRock
