Solved Grandstream GXP2200EXT with GXP2170
grantg
I'm trying to setup a GXP2170 with an attached GXP2200EXT. I can not find any configuration for the 2200EXT within the 3CX Mgmt Console. I can go into the Phone UI (phone web interface) and program the keys on the 2200EXT, but when the phone is reprovisioned all of the settings are wiped out of the 2200EXT. I read a post that suggested that after creating a certain number of BFLs the settings would flow over to the 2200EXT, but that did not work. How do I get the 2200EXT to work?
FYI...
GXP2170 fw 1.0.9.102
3CX ver 15.5.0
The BLFs start at 47 on the 2200EXT when paired with a GXP2170. My clients use 1-12 for call lines and parking. Then we have 13-46 as blank.
Worked like a charm. Thank you very much!
Is this documented somewhere?
Reactions: YiannisH_3CX
apbGroup
