Grandstream GXW-4104 making but not reciving calls.
easy2pc
Do you see the call hit the Activity of 3cx?
Can you get a capture from the GXW when this is happening?
Usually, there is an issue with the Caller ID not matching - wildcards in this case help.
Hi Craig
No i don't see anything in the log for incoming calls.
i'm not sure if you can do that on the Grandstream
The Grandstream phones allow a capture, so I assumed the Gateway did as well.
On the phones, it is under Maintenance->Packet Capture.
Hello @easy2pc
You can also run a capture from the PBX to see if calls are reaching the PBX and see what is being sent if calls do reach the PBX.
Zexus
