  • V20 Update 10 Final Learn more
Solved Grandstream WP822/825 Wifi-phone
noord
Hello!
Does anyone here have any experience with the WP822 / 825 Wifi-phones from GrandStream?
If you look at the release notes of the Grandstream firmware, you see 3CX mentioned several times (see https://firmware.grandstream.com/Release_Note_WP810_822_825_1.0.11.34.pdf)
So it seems at least GrandStream has built in some support, even for autoprovision.
Does anyone have any experience with these phones?
Hi there.
From our end, you won't find a mentioned model in the list of supported devices.
You can try and use it as a Generic device.
Thanks.
I saw the Fanvil W610W and W611W are supported and are also wifi-phones, so we’ll go with those instead!
Reactions: OlegR_3CX
Perfect!
I will close this thread now.
Have a nice weekend
Reactions: noord
BConveryCoreCare
