Group Member call notification
Samraby
We are trying to setup the following:
We have 3 users in a group
If someone Calls User A , User's B & C's BLF Light for User A Flashes and they can pickup
however there is no sort of desktop notification to users B & C
Is there a way of notifying them that User A is getting a Call ?
We will need this to work for both Soft phone and Yealkink Deskphones
If you use the Webclient, they will see the person's card with a blue bar (which contains the caller ID, and they can click to pick it up). There's no direct way of "notifying" beside BLF + Webclient.
Simple as that.
Hmm, that's a bit of a pain.
Maybe there is a better solution to our problem
We have the CEO's line and he has 2 PA's
We want their phones (or softphones) to noifiy them he has a call.
Could we use the call flow designer to say send his calls to the 2 PA's first then potentially to him ?
The CFD can't do that since once the call is transfered out of it, it has no control over the call.
It's not really a pain, you just have a specific use-case. There's no way to notify the others unless you use a RG or queue.
admintest
