Group members keep reverting back to 0 extensions after 24 hours
pmv800
Here is an image file of what I was mentioning above that keeps reverting back to 0 Total extensions.
Add the users you want to use in the User Sync (select "Sync these users only") and it won't create extensions for those if the emails match an already existing extension.
they will then appear in the group
The fix is required only if you have Contacts synchronization only. In that case, you have to manually create the group. No need to add members to it.
Thanks everyone that was the fix. Having everyone in both groups was the problem. I was able to remove everyone out of the Default group and left everyone in the new group I created.
Schnittker
