GSM adapter for Cloud solution
kirbel
Can I install gsm adapter on google 3cx cloud system? SBC, other solution or not solution?
Best Regards
Béla
Thank you for the information, I would actually be interested to see if the 3CX cloud version works with a GSM adapter installed on site? Can I establish a connection on SBC or other?
The only way you could do this is to setup a gateway onsite, use a software PfSense firewall from your remote cloud system and setup a VPN connection between the sites (IPSec LAN >> LAN).
Hi eddv123,
Thank you very mutch
Wecare_ITA
