GVC3200 video call and webconference issues
betotheone
I have gvc 3200 and is authenticated on 3CX v16 but I am unable to establish video call and access webconference via chrome. does anyone had this issue ?
Webconference only works on PC using Webmeeting.
You can dial-in for audio but not video.
Thanks Frederick
The video call is between the GVC 3200 and PC, I wan troobleshoting and I see that 3CX doesnt support
H.264 video codec that is the one supported on GVC 3200
Hi Frederick Thanks for the Reply
The video call issue is between the GVC3200 and PC, I was troubleshooting and I saw that 3CX doesnt support
H.264 video codec that is the one supported on GVC3200. I need to find a solution for this problem
Thanks Frederick
Actually, 3CX supports H.264 but only between endpoints. Videocalling to a PC, whether to webclient or Windows client, won't work.
That is my point I will not be able to establish video call between 3CX endpoints (Windows, Android, Mac and IOS) and GVC3200. or there is a way to have H.264 on 3CX endPoints (Windows, Android, Mac and IOS)
Not yet. Mobile app is in work right now.
As for desktop clients, those are about to be deprecated in favor of the webclient.
I have no idea what codecs the webclient supports tho.
If you want videocall, call between deskphones only (between GVC and a GXV for example).
In this case Is it possible to use transcoder on PBX
hughesdouglas
