Solved HALP! My System Status Graph is Doing Somersaults and/or Time Travel. (Screenshot Attached)
kruso.tech
What in the world is going on here? This is a brand new install of the 3CX Debian ISO on WS2019 Datacenter. I had 3CX running on my old ESXi server without problems.
amount of memory seems very low no?
Reactions: kruso.tech
I noticed that too. Apparently it doesn’t work well with dynamic memory. I turned dynamic memory off and increased the RAM to 2GB. Still having the same problem.
Since you mentioned Server 2019 Datacenter are you using ESXi or Hyper-V?
Reactions: nub
It would probably be best to use a process manager like top to see what is spiking the resources.
When that graph was made, the hypervisor was only allocating 512MB to the machine. I have since given it 2GB, and I’m still having the time travel issue. I don’t think it’s a resources issue.
never seen a case like yours, we discover something, :p ;)
TimeMachine edition ? :)))
Lokks like NTP was adjusting a local time...
It looks like the clock of the machine is changing, that would be enough to explain the graph.
You should look into NTP section of the guide posted above, and also ensure that the hypervisor is not doing anything weird with the time sync.
Reactions: JohnS_3CX
No worries, glad to hear it was resolved!
Robert Lee
