HARDWARE REQUIREMENTS FOR ENT/AI EDITION
Victor_Ke
Hello @TheodorosG_3CX
I have a general question regarding hardware requirements for the ENT/AI edition.
Will the hardware requirements change for the ENT/AI edition or will it require additional resources or the resources listed on 3CX website https://www.3cx.com/docs/recommended-hardware-specifications-for-3cx/ are okay for the edition?
Does it require different hardware specifications or it is the same as the pro if the ENT/AI has AI enable?
The software is the same.
Only if you plan on using local transcription engine that you will need a separate machine with a GPU and much RAM/CPU.
As mentioned from @ConceptsWeb the guideline apply no matter the license edition and also those are the minimum requirements.
tom.walker@blackcountryra
