My instanist of 3CX is running on a very old Intel machine. (Windows 8 in a previous life).
The question is should I install it on a BeeLine Mini Computer before or after I update V20?
Hi there.
So if you are using Windows OS and have the Phonesystem installed directly on it and not in the hypervisor, then Windows 8 is not supported. See the list of the supported Windows OS here. Also kindly be informed that at the current time, V20 is not available for Windows OS as a stable production release but only as Alpha so you will need to wait some time.
Additionally, keep in mind that if you will continue running on Windows directly, your license will need to be Enterprise and not Standard/PRO.
