Has SSL Renewal Procedure changed?
Yellow_Flash
I'm trying to renew the SSL certificate on Self hosted instance running a custom FQDN.
We are using certificates from Digicert.
Last time i did this, I had found an article on how to do it.
It had step by step instructions on how to do it, which I'm no longer able to find it.
Instead of that I'm getting this article.
https://www.3cx.com/docs/self-hosted-instances-ssh/
This doesn't explain how the certificate can be renewed, which is the reason for this community post.
Has the steps changed?
Or is it the same as before?
That is,
Locate folder, C:\Program Files\3CX Phone System\Bin\nginx\conf\instance1
- Confirm there are 3 files and look for, -crt.pem and -key.pem.
replace the -crt.pem file with the new certificate file while keeping the name same and the -key.pem file with the new key file.
- Restart the NGINX service.
Kindly let me know.
Thank you
Reactions: Yellow_Flash
Thank you everyone for the help. Appreciate it.
Reactions: jed
AshleyStokes
