Hide system extension option
ArneDery
Platinum Partner
we've encoutered something with the option hide system extension.
What we've done, we've configured all the call forwarding for users to when not available to go to system extensions.
After all configuration was done, the customer asked to hide the system extensions for the users.
After enabling this we cannot use any of the systemextensions anymore in the call forwarding
From a admin point of view I think if you're managing the call forwarding from the admin console, you should be able to select those.
I agree that they are hidding in the settings page of the user. However on admin level you should be able to. Am I wrong?
Current behavior also breaks any configured flow with system extensions in call forwarding when you enable hide system extensions.
Any workaround?
Honestly I thought this setting just hid it from being searchable in the address book / dialer lol
Hi, this should not be so, and it isn't in my tests. An already configured forwarding continues working as before with Hide System Extensions activated. Can you double check?
Hi re-tested on our testing environment and all goes well for the already configured forwarding.
However, trying to change the routing to for example another Digital Receptionist, you need to re-enable the system extensions.
from a admin point of view this is strange.
That is indeed the case and this is how i have been doing it. unhide, set forwarding, then hide again.
Reactions: ArneDery
