High memory usage on Hyper-V
James Wiltshire
Intermediate Cert.
I have set up 3CX on a hyper-v server using the debian iso install disk from the website, version 15.5.0. Everything is up and running but within a few minutes the memory on the hyper-v server has reaches the maximum i have set and sits there without decreasing. I have 2 extensions configured. The VM is using dynamic memory and is set to use a maximum of 16 GB of memory.
Any ideas what is causing the high memory or is this to be expected?
James
Yes, Linux is taking the memory because it can. Not exactly sure why are you are complaining since you configured the system to use up to 16GB of memory. If you want it to use less, give it less :).
https://www.linuxatemyram.com/
WagnerFT
