Hosting on Lightsail
Royal22
Gold Partner
We have started self hosting using LightSail, we now have two instances up and running using the guide available from 3CX, but when trying to add a 3rd by going to the IAM console the "Create New Access Key" its greyed out, as it turns out you can only have two Access Keys! what is the best way of adding a new 3rd 3CX instance?
Do I just keep using the same two keys for any future 3CX instances?
The access keys are like credentials to your AWS account. You don't have to create one every time for each install, just use the same one.
Reactions: Royal22
Is there any limits you know of, or can you just keep adding instances?
I'm not sure what I'm doing wrong here, but if I try and use the same two ID & Key I have previously used I now get this error!
Sorry, you've reached your maximum limit of Lightsail Instances : 2. If you're new to Lightsail, please try again later. If the issue persists, please contact Amazon Lightsail Customer Support.
I'm just doing this through the same process as I did with the other two 3CX instances I have created via the 3CX portal.
FYI - I have been in touch with AWS, this is limits set by them on new accounts(ours is 6 weeks old), they will increase the limit which can take 24/48 hours.
TVV40
