- Joined
- Aug 15, 2017
- Messages
- 500
- Reaction score
- 57
Version 15.5, Yeallink T58
I would like to use hotdesking, however, it seems users can only login if voicemail is enabled. If I disable voicemail there is a message about extension not found and the login process terminates.
Also, is it possible to logout a user at a schedule during the night?
The documentation says hotdesking will not work with the windows client, but I found no problems, I can dial a number, and the software picks up the extension. What are the possible problems I have to expect?
