Hotfix for v16 Update 4 and Update 5 Alpha
  • Thread starter Thread starter Constantinos Constantinou
  • Start date Start date
In response to the upcoming release of Chrome and Microsoft\'s New Edge browser version 81 scheduled for sometime next week, we have released a Hotfix update for v16 Update 4 and prior as well as Update 5 Alpha. The hotfix is required to be installed on all v16 PBX versions to maintain WebRTC compliance. This Hotfix applies only to call functionali...
Our system says "server error" after installing this update. Completely down
@bcarrico can you ensure that all 3CX Services including nginx are running? If you need help pm.
Hi there,
We faced same issue since we went on to v16 Update 4 (latest stable).
This morning 3CXPhoneSystemMC01 failed.
Looking through the logs this is the only relevant logs so far:
Apr 3 10:20:47 3cx kernel: [16270545.612584] 3CXManagementCo[20203]: segfault at 0 ip 00007f3b18bff599 sp 00007f3a688db9e0 error 4 in libVCEWebRTCHandler.so[7f3b18bc5000+4f000]
Apr 3 10:20:49 3cx systemd[1]: 3CXPhoneSystemMC01.service: Main process exited, code=killed, status=11/SEGV
Apr 3 10:20:49 3cx systemd[1]: 3CXPhoneSystemMC01.service: Unit entered failed state.
Apr 3 10:20:49 3cx systemd[1]: 3CXPhoneSystemMC01.service: Failed with result 'signal'.
@[B]saintanger99[/B], its caused due to a race condition when a call is initiated via WebClient or Browser Extension and when Early Media is engaged, call is dropped at the same time.
This has been fixed in Update 5 Beta, so we recommend you to update.
Hi Michael,
Thanks for the reply. We went for Update 4 yesterday as it was the latest stable. We'll update tonight or when the issue reappears to avoid downtime.
Any known issues upgrading to Update 5 Beta that we need to be aware? Don't really want to get in a worse position.
Look from the feedback we've got we have good promising feedback I must say. Of Course due to this epidemic I cannot guarantee 100% that everything works smoothly but what I can say for sure that the build you have is getting closer to be released on Final. What I can say you have 2 options here;
Option 1: You wait another week or 1 week and half for Final.
Option 2: You spawn a replica of your machine you update to Update 5 leaving production as is you verify that everything went well and then you can move forward to updating production.
Look, I cannot provide you patches as due that Update 5 has improvements in libraries, update to latest .net core and many other things.
Also if you are using IOS and you are running a Windows host? Ensure that the Operating System is Window 10, 2016 or 2019.
Hi Michael,
We're actually running debian 9 via ovh cloud as 3cx host, these logs were syslog.
Hope the above means we're good to upgrade our debian 3cx host to Update 5.
Cheers
OK then..
Hi Michael,
I have a question that I couldn't solve reading the article.
I can conclude that if I'm not running updates 4 or 5 my system won't be affected? Or every version will be affected and only updates 4 and 5 will receive the hotfix?
Thanks in advance.
Regards,
DaanLosning
