How can I get the 18.0.6 3cx IOS for Linux. My system is prompting me to update t0 the latest release but I am reluctant.
Rasreby
I already upgraded to 18.0.6 Beta but then I had to do a reinstall with my original IOS. However when I tried to restore the system tells me my backup version is later than my installed version. I had to restore an older backup i had before I upgraded to 18.0.6.
Basically, you do the install and set up 3CX as a new install using your license.
Once youre in the mgmt console, run the updates until there are no more.
You will need to copy your backup to the location within the OS and then you can perform a restore.
Thank you. Can you specify the location path within the OS.
When you run "apt-cache policy 3cxpbx " in terminal what version is shown as installed?
18.0 (Build 908)
Jeremy Hofex
