How do I block outside calls from dialing a particular extension system wide?
redbudindustries
Forum User
I have an extension that is tied to a Snom PA1 paging system. If an outside person calls they can dial the extension 111 and reach the paging system, which auto answers. How do I disable one extension from being reached by external calls but keep it open for internal? I have played around with forwarding rules but cannot seem to get the desired result. I also have tried putting the extension 111 in a custom setting I found to exclude extensions from being reached from IVR's Any ideas on how to handle this scenario would be greatly appreciated.
Thank you
Thank you for the response. I am still unable to block direct dial from IVR's by using the above recommendation.
that parameter doesnt work in v15.
Try this
IVR_DIRECT_DIALING_GRAMMAR is simply a regular expression. Adjust that parameter to suit your needs and restart the services, or easier just restart the server.
As an example the below regular expression, aka what is set for IVR_DIRECT_DIALING_GRAMMAR, disables the ability to dial extensions 2400 and 2500 while still recognizing four digit extensions:
((?!2400|2500)[0-9]{4})
Another example if you want to disable all direct dialing all together use the below to recognize only one digit between zero and nine :
[0-9]{1}
https://www.3cx.com/community/threads/ivrdonotcall-not-applying.49378/
fransisco
