Solved How do I change from own SSL to 3CX SSL?
[email protected]
We are having to reinstall 3CX tonight to fix another problem, and we will be restoring from a 3CX backup. How do we change to the 3CX Certificate. We had been using a wildcard cert that is going to expire soon. I figured I might as well change it. Any ideas?
Take a backup without key/cert. Uninstall. Release FQDN from the customer portal. Reinstall/restore and choose the 3CX provided FQDN. Then have a beer for making your life easier :)
Thanks for the tip. :) I will do that. Any idea how to ensure the cert is gone before I run the backup? When I enabled it a long time ago, I remember messing with config files in C:\Program Files\3CX Phone System\Bin\nginx\conf\instance1.
It was a success. :) Thanks!
GP Concepts
