How to bind a CFA to a DID in v20 ?
idovoip
Hello everyone
I'm currently testing v20 and wanted to test my CFAs. However I'm already failing at square one. I can't seem to find a way to bind a CFA to a DID. In v18 I would normally bind the CFA to an inbound rule for example. How would I go about doing this in v20 ?
CFDs are not in v20 yet. They work but there's no UI to upload/manage them.
Probably because of that.
@onceptsWeb
Now that explains a lot !
I've noticed that I could create a group, a queue or a receptionist and select to trigger a CFA there but again no way to upload the CFA ...
Can we get an estimation on when we'll be able to get a UI element to upload / manage CFAs ? Assuming that the necessary code is in place, a simple link to upload CFAs for testing purposes would be fine I guess.
I would even be fine with just putting the apps at a certain place in the filesystem if that would allow me to select / manage an app.
This will be included in the final v20, but the preview we released is quite limited in this matter. You can always use the old Management Console from "/deprecated" to upload the CFD app and do what you can't do from the Web Client yet.
Will that be available until the v20 has all the settings? Like probably U1 or U2.
@edossantos
Thanks for mentioning "/deprecated". I was completely unaware of that functionality
Yes, it will be available for some time.
so is this now gone for sure as I've got a headache with inbound parameters after my upgrade to v20 and i cant find any way to change them
Has the "/deprecated" option been removed? I am trying to upload a CFD but adding "/deprecated" to my URL does not work ( self/cloud hosted )
Admin Console > Integrations > Call Flow Apps
Reactions: edossantos
mazet
