Solved How to call Dynamic 365 CRM API from Call Flow Designer
Tin Nwe Win
Gold Partner
Can you please help me with how to do Authentication to call Dynamic 365 CRM API from CFD?
I want to update CRM's contact activity.
So, I implement the CFD as below -
1) Create Survey Component
2) Get CRM's Contact ID using CRMLookup Component
3) Update Caller's feedback to CRM's Contact Activity Timeline using CRM API
In this Item No 3, I can't access to CRM API and returned 401 status code.
For OAuth 2, can I use the refresh token from 3CX CRM Integration?
I hope that you guys can provide solution. I need this urgent.
Thank you in advance for your help.
Reactions: Rashid Raza
@edossantos
Thanks for your reply.
How to do to get CRMINT_DEFAULT and can I use Refresh Token from CRM Integration as hardcode?
@edossantos
Thank you for your help.
I will try it and update the status.
@edossantos
Thank you so much for your help.
You may close this post
Reactions: edossantos
Robert Lee
