How to configure 3cx to accept UPDATE SDP message from carrier?
Sohaib Eltantawi
I see on the logs that if my sip trunk carrier sends UPDATE SDP message to 3cx, 3cx will send 500 internal server error.
I attached a PCAP file showing that.
Thanks,
I saw this post but I don't see the solution!
The solution was to send the support files (not just a wireshark trace) to support, basically the 3cx should handle UPDATE messages so there seems to be something wroing with your 3CX
Hi Ritter
Shall I attach the support file here?
Hi, No not a good idea, as support is not provided through the forum.
Is this a tested supported VoIP provider with 3cx?
Yes, It's tested.
The incoming calls with no update message work fine but, the issue occurred when an update message comes in the call.
Which provider is this related to, please?
  • Haha
Reactions: Alejandro_3CX
STC in Saudi Arabia.
OK, thank you.
VOIPEric
