How to configure a SIP trunk to send one-way SMS / Alphanumeric Sender ID SMS?
kaiserh
In 3CX, you're supposed to be able to configure a SIP trunk with an alphanumeric sender ID, so that you can send one-way SMS messages.
https://www.3cx.com/live-chat/business-text/
What is a one-way SMS, and how does it work?
A one-way SMS uses an alphanumeric sender ID to send notifications, such as order updates or appointment reminders.
3CX supports Twilio as an offical SIP trunk provider
https://www.3cx.com/docs/sip-trunk/twilio/
Twilio supports the ability to have an alphanumeric sender ID so that you can send SMS messages and the recipient sees the message comes from a named entity, not a mobile number. This also means that the recipient can not reply to the SMS, which is exactly what I want.
Is there any way to configure 3CX to send SMS messages via Twilio with an alphanumeric sender ID?
I dont think its possible to configure from 3CX, IIRC i've tried doing this myself once upon a time.
Yeah, I think you're right.
As it turns out, it looks like 3CX will receive one-way SMS with an alphanumeric sender ID, but it won't send them.
I had to create a helper running as a Cloudflare Worker to receive the text from 3CX, and then forward it to Twilio with my Messaging Service SID and it's all working perfectly.
Reactions: KyriacosS_3CX
Easy thing to do?
id like to be able to send alphanumeric
youwillbrun
